Uniden HR2510 (Repair help needed)
221Big D
Feb 12, 2015
14
43
This radio has very low tx power. You can hear audio from a nearby radio. All modes are same... I dont know much but I'm trying to learn and figure this out..
Q132 Voltages
Rx
B 0
C 14
E 0
TX
B .766
C 14
E .002
Q133
B 0
C 14
E 0
TX
B 7.95.
C 14
E .001
Base voltage on Q133 during tx is way off... Cant figure out why..
Thanks for any help I can get...
#221 NC
Remove ALL of the conductive dried brown/cream color glue on and around components. This stuff will cause shorts when it ages with time and heat.
Use a solvent like acetone or GC Radio-TV Service Solvent on a Q-tip to loosen the glue first. Then gently pick and pull it off with tweezers when it is softened. Or the more time consuming but more effective way is to remove the component and soak it in the solvent, then remove. Don't go picking and prying it off with 400 pound gorilla force. This will cause more headaches.
Also, an entire re-cap of the radio is a very good idea. These gals are getting up there in age.
