Uniden washington low power
123michigan
May 19, 2005
92
2
16
newberry michigan
hello all playuing with a uniden washington right now while the hf is down bein repaired. this radio has sat quite a while was completlyt virgin. but only showed 2 watts am and 10 watts ssb. i did the peak and tune did an alignment on the radio and still only showing about 13 watts on ssb and a max set dead key on am of 5 watts(not that i want it any higher, but should have the ability to do more). radio has excellent audio otherwise and not sure which way to go with this. thanks in advance for the help.
supermog kit
i used to one and i was expencering the same thing,back years ago then i found out about a supermog kit that will put more audio and a lot more swing,i bont know if they make them anymore but mine woked wonderfully.just a thought
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
