Update from earlier post
Tripple Nickel
147
19
82
Monroe, Georgia USA
I needed to hook up my D-104 amp mic to my Uniden Washington radio. I ordered what I had found on Ebay was the correct #c4p5c 4 pin male to 5 pin female. Not only did it not fit my radio because the barrel part was not the correct size, I sent an email with no reply from the seller. then made a couple of phone calls only to get voice mail several tries. Ebay does have a good policy protecting buyers form this, but the fact remains I still don't have the correct one to use my lollypop.
Does anyone know what part # I need, and where can I get one with a reputable company ? I sure hope someone can help me with a small problem, looking to hear from you. Good Day as Paul Harvey would say.
555
Here's what I use to connect a 4 pin mic to a 5 pin cobra/grant xl/uniden washington -
http://tinyurl.com/oozufbc
It's the same part number, maybe you got a mispick?
Thanks, it has a completely different plug in part to the radio, which will definately work, even the QUALITY of this one is much different. BTW, how did tou wire your mic. I'm going to put a new plug on my D 104 and just need wiring ie 1,2,3,4 pins. For some reason McAfee will not let me download the Astatic page which I used to have. Again, thank
Thanks, this is it, better QUALITY. Do you have wiring info for the 4 pin, I'm putting a new plug on the D-104 ?
