Varmint XL250
silvereagle1
174
21
Helo Everyone! I have a Varmint XL250 amp. The amp works good and puts out what it should but when you hook up the antenna it kills the receve on the Raido. Now that being said you can talk on it and still here but you cant here very well. Any help here Iwould be greatfull. Thanks.
sounds like the relay could be hanging
if you key the mic then let off will it open up the relay then you can rx better
OK I tryed it and they are working foir about the first 2 min then after it gets warmed up the keying relay stops working. Any help there.
