If you're referring to R133, no, it's not part of the clarifier circuit from what I can tell. However, it almost looks like J28 was put in specifically for the Viagra boards. Interesting.
Anyhow, put in a 47 ohm resistor at R133, or snip the positive power wire off the connector of the Viagra board that plugs into J28 and solder that wire to JP190 for a stable +8V source to power the board. Good luck!
~Cheers~
