W4BUG repeater, from Nassau Bahamas
avistar23
184
32
38
35
Nassau Bahamas
Guys im very happy to report that tonight i finally hit a repeater in south Florida
i coudlnt belive it, ive been working on my VHF setup for quite some time, and i finally had success, members on this board directed me to GulphAlpha and i must admit his antenna did the job, i attached a recording before it the repeater of its receive strength over 200 miles away.
VID-20130725-00000 - YouTube
during the conversation i was far to happy to record. ^^ ab v c^^(y):D(y)
Reactions: Goonie
70 watts out of the mobile into this
you can see my other question about an amp in the amp section.
If this is the repeater in FL that you worked,...
more than likely it was one of these:
Gold Coast Amateur Radio Association
Club Repeaters
OUTPUT: 146.61 MHz
INPUT: 146.01 MHz. PL 110.9 Hz.
at I-95 and Atlantic Blvd. in Pompano Beach
REMOTE RX: Briarwood Apts rooftop
at University and Sample in Coral Springs
OUTPUT: 146.82 MHz
INPUT: 146.22 MHz. PL 110.9 Hz.
Boca Raton
OUTPUT: 442.50 MHz
INPUT: 447.50 MHz. PL 151.4 Hz.
OUTPUT: 442.20 MHz
INPUT: 447.20 MHz. D-STAR SYSTEM
OUTPUT 145.340 MHz
INPUT 144.740 MHz D-STAR SYSTEM
LOCATION Imperial Point Hospital rooftop
You must keep in mind, that dx'ing repeaters is not proper operating practice. Although within the rules, that is not what repeaters are intended for. Who are you going to exchange QSL cards with, the repeater?.
Rich
.... if you spent a long time hunting weak signal VHF and finally had some activity wouldn't you jump on it to? after investing lots of hard time and money?
every single person active at that time on it was more than excited to converse.
i also was sent many QSL cards by operators on that repeater. you must love IRLP then.
I don't want get into a fight here, but you only made contact with one station. Think about it, if you did not go through the repeater, who would you have worked. Next time ask them to qsy to 52 simplex.
Rich
Regardless if it was "just a repeater" it was still a good contact. That's quite a long haul for FM especially. Reminds me of the time a guy in Eastport Maine made it into our VE1OM repeater at 150 miles. He was using an HT at the time. Nobody criticized him for working thru a repeater.Quite the opposite actually. It`s not so much WHO you talk to but rather the distance you talked. It could have just as easily been a mobile parked on the hilltop he worked into.
Reactions: avistar23
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
