Washington
MonsterAudio
Mar 17, 2011
22
Hey all,
i have this little Washington in here,
i have TX but no Rx, i can hear static (normal white Nice every radio makes before you hook an antenna to it)but no incoming stations, not even my handheld 2' away..
i keyed the radio with no coax attached by accident (bad jumper), i have changed the jumper and changed it to a different antenna (i have a dual polarity as well as an omni),
does anybody have any suggestions on what i need to change to fix this problem or at least a specific starting point?
any help is greatly appreciated
Well your radio is broken. Hope that helps.
And what does "Monater" spell or mean? Did you mean "monitor" as is monitoring a radio?
o wow, it was suppose to be "Monster" damnit.
i had an account here a couple years ago but dont have the email anymore so i couldnt get the old password...
and no shit on its broken, is that your professional opinion :D
Oh heck naw. I'm an amateur.
You can PM a moderator and they can correct the spelling in your user name for you. Great guys....every one of them!
lol, im an amateur also, just been playing with these things since the 70's.
i cant believe i hit the a and didnt catch it, its bad to get old!:D
MONSTERAUDIO -
You didn't say which Washington you have... there are two different models. One used the Upd858 pll chip, and the other uses the MB8719. If you have the 8719 model then the link provided by Robb is your ticket. But if it's the 858 model, then the problem is probably the T/R relay. Cleaning the relay contacts usually fixes things. Good luck.
- 399
OK I just tried to find a 18.2 v zener diode and had no luck, plenty of just 18v, but what watage do I need?
Does anyone know the diode numbers from that cbtricks page to use?
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
