What are Amplifier Classes?
TonyV225
Apr 18, 2005
5,824
323
143
Wisconsin
I know some argue facts on amplifiers while some really honeslty really dont know or understand them or their classes sho I hope this clarifies alot of it and its more understandable. Classes also referred to in audio equipment. This should help a bit in understand what the classes do or the quality.
The Class of an amplifier refers to the design of the circuitry within the amp. For audio amplifiers, the Class of amp refers to the output stage of the amp (in practice there may be several classes of signal level amplifier within a single unit). There are many classes used for audio amps. The following is brief description of some of the more common amplifier classes you may have heard of.
Class A: Class A amplifiers have very low distortion (lowest distortion occurs when the volume is low) however they are very inefficient and are rarely used for high power designs. The distortion is low because the transistors in the amp are biased such that they are half "on" when the amp is idling (this is the point at which the semiconductor devices are most linear in behavior). As a result of being half on at idle, a lot of power is dissipated in the devices even when the amp has no music playing! Class A amps are often used for "signal" level circuits (where power requirements are small) because they maintain low distortion. High end Class A audio amplifiers are sometimes used by the most discriminating audiophiles. Distortion for class A amps increases as the signal approaches clipping, as the signal is reaching the limits of voltage swing for the circuit. Some class A amps have speakers connected via capacitive coupling.
Class B: Class B amplifiers are used in low cost designs or designs where sound quality is not that important. Class B amplifiers are significantly more efficient than class A amps, however they suffer from bad distortion when the signal level is low (the distortion in this region of operation is called "crossover distortion"). Class B is used most often where economy of design is needed. Before the advent of IC amplifiers, class B amplifiers were common in clock radio circuits, pocket transistor radios, or other applications where quality of sound is not that critical. For example, a siren driver is one application of a Class B amp. Siren drivers are amplifiers that are basically driven into clipping (to produce a square wave type signal). In such a drive situation there would be little need to care about crossover distortion (the design can be less expensive due to reduced parts count).
ClassAB: Class AB is probably the most common amplifier class currently used in home stereo and similar amplifiers. Class AB amps combine the good points of class A and B amps. They have the improved efficiency of class B amps and distortion performance that is a lot closer to that of a class A amp. With such amplifiers, distortion is worst when the signal is low, and generally lowest when the signal is just reaching the point of clipping. Class AB amps (like class B) use pairs of transistors, both of them being biased slightly ON so that the crossover distortion (associated with Class B amps) is largely eliminated.
Class C: Class C amps are never used for audio circuits. They are commonly used in RF circuits. Class C amplifiers operate the output transistor in a state that results in tremendous distortion (it would be totally unsuitable for audio reproduction). However, the RF circuits where Class C amps are used employ filtering so that the final signal is completely acceptable. Class C amps are quite efficient.
Class D: The concept of a Class D amp has been around for a long time (~ 50 years or so), however only fairly recently have they become more commonly used in consumer applications. Due to improvements in the speed, power capacity and efficiency of modern semiconductor devices, applications using Class D amps have become affordable for the common person. Class D amplifiers use a completely different method of amplification as compared to Class A, B and AB. Whereas the aforementioned classes of amplifier operate the semiconductor devices in the linear mode, Class D amplifiers operate the output semiconductor devices as switches (ON or OFF). In a Class D amplifier, the input signal is compared with a high frequency triangle wave, resulting in the generation of a Pulse Width Modulation (PWM) type signal. This signal (which some people incorrectly identify as a “digital” signal) is then applied to a special filter that removes all the unwanted high frequency by-products of the PWM stage. The output of the filter drives the speaker. Please note that this is a VERY high level idea of how Class D amplifiers work! Class D amps are (today) most often found in car audio subwoofer amplifiers. The major advantage of Class D amplifiers is that they have the potential for very good efficiency (due to the fact that the semiconductor devices are ON or OFF in the power stage, resulting in low power dissipation in the device as compared to linear amplifier classes). One notable disadvantage of Class D amplifiers: they are fairly complicated and special care is required in their design (to make them reliable). Due to the high frequencies that are present in the audio signal (as a result of the PWM stage), Class D amps used for car stereo applications are often limited to subwoofer frequencies, however designs are improving all the time. It will not be too long before a full band class D amp becomes commonplace and less costly. Class D amps find use in many other applications besides audio. Class D amplifiers will probably eventually revolutionize audio power amplifiers: when they are perfected, their efficiency will allow outputs of 1000+ watts without the need for a cooling fan! They will also be small and lightweight compared to the class AB designs that are most common today.
Other classes: There are a number of other classes of amplifiers, such as G, H, S, etc. Although some experts would certainly argue with me, most of these designs are actually clever variations of the class AB design, however they result in higher efficiency for designs that require very high output levels (500W and up for example). At this time I will not go into the details of all of these other classes. Suffice to note that Class D (among A, B, AB, D, S, G, H classes) is the class that represents a major delta in the way it operates as compared to the other audio amplifier classes. Sometimes the consumer marketplace promotes Class D amplifiers as being "digital". The marketplace tends to toss around the word "digital" a lot, there is no really standardized definition (that I am aware of) that deems an amp "digital". To find out what a vendor means when they use the word digital with regard to an amp requires research into the design of the amp. Most likely the vendor is just using a buzz word that the consumer may associate with a superior technology.
here's some info on RF amps , what their bias means and their correct use .
Classes of Amplifier Operation
"Amplifier Classes of Operation
Amplifier operation is distinctly different depending on the class of operation.
RF amplifiers are classified A, AB, B or C according to the phase-angle (number of degrees of current flow during each 360-degree RF cycle) over which plate- or collector-current flows.
Class A Amplifiers
Class A amplifiers operate over a relatively small portion of a tube’s plate-current or a transistor’s collector-current range and have continuous plate- or collector-current flow throughout each RF cycle. Their efficiency in converting DC-source-power to RF-output-power is poor. DC source power that is not converted to radio frequency output power is dissipated as heat. However, in compensation, Class A amplifiers have greater input-to-output waveform linearity (lower output-signal distortion) than any other amplifier class. They are most commonly used in small-signal applications where linearity is more important than power efficiency, but also are sometimes used in large-signal applications where the need for extraordinarily high linearity outweighs cost and heat disadvantages associated with poor power efficiency.
Class B Amplifiers
Class B amplifiers have their tube control-grids or transistor bases biased near plate- or collector-current cutoff, causing plate- or collector-current to flow only during approximately 180 degrees of each RF cycle. That causes the DC-source-power to RF-output-power efficiency to be much higher than with Class A amplifiers, but at the cost of severe output cycle waveform distortion. That waveform distortion is greatly reduced in practical designs by using relatively high-Q resonant output “tank” circuits to reconstruct full RF cycles.
The effect is the same in principle as pushing a child in a swing through half-swing-cycles and letting the natural oscillatory characteristics of the swing move the child through the other half-cycles. However, low sine-wave distortion results in either case only if the Q of the oscillatory circuit (the tank circuit or the swing) is sufficiently high. Unless the Q is infinite, which it never can be, the amplitude of one-half cycle will be larger than the other, which is another way of saying there always will be some amount of harmonic energy. (Coupling an antenna system too tightly to the resonant output tank circuit of an amplifier will lower its Q, increasing the percentage of harmonic content in the output.)
Another effective method commonly used to greatly reduce Class B RF amplifier output waveform distortion (harmonic content) is to employ two amplifiers operating in “push-pull” such that one conducts on half-cycles where the other is in plate- or collector-current cutoff. Oscillatory tank circuits are still used in the outputs of Class B push-pull amplifiers to smooth switching transitions from the conduction of one amplifier to the other, and to correct other nonlinearities, but lower-Q tank circuits can be used for given percentages of harmonic content in the output. (Tank circuits can be loaded more-heavily for given percentages of harmonic output where two amplifiers operate in push-pull.)
Class AB Amplifiers
As the designation suggests, Class AB amplifiers are compromises between Class A and Class B operation. They are biased so plate- or collector-current flows less than 360 degrees, but more than 180 degrees, of each RF cycle. Any bias-point between those limits can be used, which provides a continuous selection-range extending from low-distortion, low-efficiency on one end to higher-distortion, higher-efficiency on the other.
Class AB amplifiers are widely used in SSB linear amplifier applications where low-distortion and high power-efficiency tend to both be very important. Push-pull Class AB amplifiers are especially attractive in SSB linear amplifier applications, because the greater linearity resulting from having one amplifier or the other always conducting makes it possible to bias push-pull Class AB amplifiers closer to the Class B end of the AB scale where the power-efficiency is higher. Alternatively, push-pull Class AB amplifiers can be biased far enough toward the highly-linear Class A end of the scale to make broadband operation without resonant tank circuits possible in applications where broadband operation or freedom from tuning is more important than power-efficiency.
Class C Amplifiers
Class C amplifiers are biased well beyond cutoff, so that plate- or collector-current flows less than 180 degrees of each RF cycle. That provides even higher power-efficiency than Class B operation, but with the penalty of even higher input-to-output nonlinearity, making use of relatively high-Q resonant output tank circuits to restore complete RF sine-wave cycles essential. High amplifying-nonlinearity makes them unsuitable to amplify AM, DSB, or SSB signals.
However, most Class C amplifiers can be amplitude-modulated with acceptably low distortion by varying plate- or collector-voltage, because they generally are operated in the region of plate- or collector-saturation so that the RF output voltage is very closely dependent upon instantaneous DC plate- or collector-voltage. They also are commonly used in CW and frequency-shift-keyed radiotelegraph applications and in phase- and frequency-modulated transmitter applications where signal amplitudes remain constant.
Jim so many people just dont get it!! Time after time it turns into an argument and I figure start with basics and move on from there ;)
All this time I thought amplifier classes were something at the local community college. :confused:
This fella may have an opening in his classroom you could go to the site attached at the begining and Im thinking it may cost more than $10,000 because this fella seems serious about the amplifier and radio world Ive never met him personaly but this maybe right up some peoples alley.
http://www.youtube.com/watch?v=pSyYYxRlELc
YouTube - ‪CBRadioChat.com speaks with AMPOWER!‬‏
HAHAHA! dude sounds like hes a had a few. and is defintely using that tree to keep him up!!:whistle:
Do we not have a GLR on this forum?:confused:
WHY YES YES WE DO!!! GLR is a good guy that is like most of us here that can point out $h!+ when we see it or smell it and it has a tendency of ruffeling some feathers when some of us actually speak out about it after seeing it go to long without being pointed out. Its kind of the p!$$ing on someones parade kind of thing. Im still laughing out loud at your reply to that VIDE:LOL:!!
Actually the star of that VIDE:LOL: use to be a member here or was actually here I should say. Now days I dont know what ever happen to the (Godfather) as he claims he was here everyday and I think he even at one point had an AM POWER forum section.
