Greetings. I posted this on another forum and have had several "lookers" but no responses:
I recently made a 4:1 Balun that I plan on using with a new Carolina Windom that I am building. I took the recipe out of Jerry Sevic's book. I connected a 200 ohm resistor across the output using 6 inch grabbers, and connected it to an MFJ analyzer using a one foot long coax jumper terminated with pl239's, to read the SWR. Starting at 1.8 MHz I got a 1.1 SWR. It changed to 1.2 at ~7.3 Mhz, 1.3 at 14MHz, 1.4 at 18 MHz thru 25MHz, and back down to 1.2 at 30 MHz. Just for completion sake, it was 1.5 from 50 to 54 MHz and went to 2.7 at 70 MHz.
Is this normal, or have I done something wrong that needs to be looked at more closely. Is it possible the grabber hooks and leads are contributing to the error?
Here's a picture; maybe there is something wrong with the assembly(?):
Thank you for any input and insight into this.
Gerry, kk4fpo
Gerry, kk4fpo
