Rick,
You can look on QTH classifieds and in the antenna section there is a manufacture out of GA I think that sells the hubs for the quads, 3" with reducers down to 2" boom size.
I purchased four of them and built a four element quad for 11 meters, it was a monster, worked great 15 feet off the ground on the test tower.
NO way in heck was I ever going to try and put that heavy beast up a tower, so I settled for a two element and it works great.
As Doc said it is a mechanical thing, the other consideration is not "IF" the quad comes apart once it is up in the air, it is "WHEN" it comes apart, and it will come apart in bad weather.
With that said they are a heck of an antenna, work great and all that stuff, so have fun with it, just keep in mind everythng is heavy duty from the ground up as Doc allready mentioned to you.
