Wouxun KG-UV3D fails to program
KC2ZPK
Dec 15, 2010
64
Well.... It's not the usual USB conflicts, USB is working fine. The radio resets as the software attempts to read or write to the radio. The same happens if I try to clone as well, so it is not limited to the USB cable. And the LED light stopped working as well.
I opened up the radio and found some white residue near the mic/programming plugs, maybe corrosion, not sure. Any place to look for more issues?
Thanks
