Wow...I'm stoked.....
I wish I could Beetle, but I already purchased an antenna tuner that only has an SO-239 connection, so I'd have to convert the line to coax at some point.
We'll get it figured out one way or another.....
Then make How To Make A Homebrew 4:1 Balun by dxzone.comor purchase 4:1 High Power Current Balun from DX Engineeringa balun for the transition. Keep the coax run into the shack from the balun short (not over 12 to 15ft.) but I would keep the balun outside as to avert RF in the shack.
Wayne C.
Wayne C.
Problem with just randomly grabbing a 4:1 (or any other ratio besides 1:1) balun without first determining the actual impedance at the point you're inserting the balun: suppose the impedance is 300 ohms. The balun will transform it to 75 ohms (300:75 = 4:1). Now suppose the impedance is already 75 ohms - very possible. That same balun will transform it to less than 20 ohms.
This isn't saying it won't work; it just won't work as efficiently as it could.
