Yaesu FL-2100B 12 Meter modification
Crambone,
An SWR bridge is another term for an SWR meter. The text is having you check the input from your radio through the 10 meter tuning coil. Best results are had by terminating the amplifier into a dummy load.
(Probably not a bad idea to check the tune in all band positions while at it.)
David
Reactions: wavrider
Crambone,
David
OK that makes sense I was reading into it too far.
Thank you for clarifying
