Yaesu FT 900 problem
ct1dz
Nov 28, 2010
55
Hello good evening I have a Yaesu Ft-900 which is currently transmitting with less power that is in-3.5mz 7.00mhz-100w 14,21,28 and from there only 50w someone happened to you this will be the final transistors or drives needed help if a colleague has ever happened to it.
Thanks
Fernando Dinis Silva
CT1DZ
You should be posting this in the "Tech, & Repair" section to get a wider audience and a better chance of getting an answer.
tracker.
  • @ Tim Chambers:
