I've found an extended freq. mod.
The famous mod for ext. frequency on 2 mtr and 70 cm ( the 4th solderpoint). Is more extended as we all know.
When you remove this solderpoint the freq. range is 6 mtr as well. You can transmit between 50 Mhz and 54 Mhz The only thing is that you need a antenna for this frequency.
Diamond do have such a antenna for about $30.00 I'm not responsible for any dammage on your porto. It works very good for me.
