Yaesu VX-8r mod - first on the internet!
Discussion in 'Yaesu' started by Moleculo, Jan 4, 2009.
  1. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,814
    819
    This mod enables out of band TX on the Yaesu VX-8r.
    Here's how to do it:
    -Take out the battery.
    -Under the battery is a heavy, thick plastic cover with very strong adhesive. Remove it using an XActo knife or a very small screwdriver that you can slip under it. This is the same cover you need to lift to install the Bluetooth option.
    -After you get the cover open, it will look like this:
    [​IMG]
    To mod the radio for out of band TX, locate the only resistor visible on the board, just to the left of the bluetooth plug:
    [​IMG]
    All you have to do is carefully remove this resistor. I have a fine tip for my solder station for little work like this:
    [​IMG]
    Make sure you clean off ALL the residual adhesive. Don't try to put back the cover that you took off, as it will be badly deformed and you will have lost some of the adhesive. Yaesu gives you several extra covers in the bottom of the box, so use a new one. This is important to preserve the waterproof integrity of the radio!
    After you put the battery back in, the radio will have reset and you will lose all of your settings. I'm not sure what the complete range of TX is yet, but this mod definately opened it to TX out of the Amateur bands.
    FIRST! (y)(y)
    #1 Moleculo, Jan 4, 2009
    CIGAR DUDE likes this.
  2. Happy_Hamer
    Happy_Hamer
    Expand Collapse
    Administrator
    Staff Member
    Mar 22, 2001
    5,045
    135
    in PDF
  3. kf4lza
    kf4lza
    Expand Collapse
    Jan 5, 2009
    2
    uh oh...
    Darn, this mod is only a Mars/Cap mod not a freeband mod like on the VX-7R. I was hoping to open up TX into 47 MHz. It's a no go I am afraid. Hopefully there is a resistor to pluck for a freeband mod of some sort hopefully we can find it.
    73's
  4. KG6NSB
    KG6NSB
    Expand Collapse
    Jan 5, 2009
    2
    Thanks for that info, LZA, before I voided my warranty!
  5. fbwebdes
    fbwebdes
    Expand Collapse
    Jan 6, 2009
    Does anyone know what bands are opened up once this mod is completed?
  6. nicoderm
    nicoderm
    Expand Collapse
    Jan 6, 2009
    2
    i tested frs,155/465 tx. works fine
    thanks mole for the info
  7. k8cix
    k8cix
    Expand Collapse
    Jan 7, 2009
    2
    Question: vx-8r mod. reset
    The mod for the vx-8r for mars/cap says "after the battery is replaced the radio will reset and you will lose all your settings"
    Question 1: Does the radio reset automatically or do you have to do a reset and which one?
    Question 2: What settings are lost. Are the default settings intact or do you have to input ALL settings?
    Roger, K8CIX
  8. W5LZ
    W5LZ
    Expand Collapse
    Crotchety Old Bastard
    Apr 8, 2005
    6,832
    748
    Q-1. It sounds like it ought to do the reset automatically. If not, do it manually.
    Q-2. It sounds like anything you programmed into it will be gone. Writing the settings down before doing the mod sounds like a real good idea! Then reprogram it.
  9. nicoderm
    nicoderm
    Expand Collapse
    Jan 6, 2009
    2
    it will reset it self and yes you do lose all your data.
  10. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,814
    819
    Yep, that's what it did to mine.
  11. alaskann7phb
    alaskann7phb
    Expand Collapse
    Jan 7, 2009
    2
    Question VX-8R capability
    Next question, does this radio transmit AM on aircraft band (122.900) as does the VX-7R?
  12. k8cix
    k8cix
    Expand Collapse
    Jan 7, 2009
    2
    vx8r mars/cap mod.
    Thanks for the info so far on the reset and loss of memory. I guess my main concern is that ALL default (factory) menu items are lost. I don't mind losing the freq.'s I have programed I just don't relish the idea of having to go to 100+ menu items for reprograming. Is this what you have to do?
    Roger, K8CIX
  13. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,814
    819
    No, it doesn't
    On mine, the radio just got set back to the default, as it was when I first took it out of the box. All of the pre-programmed VHF Marine, SWL, and other special memories were preserved.
  14. plato
    plato
    Expand Collapse
    Jan 14, 2009
    VX-8R tx.range after the mod.
    Does any one know the tx. range after the mod? I am interested in the 503-512 Mhz. range. Thanks. Plato:
  15. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,814
    819
    TX range after the mod is:
    50-54
    140-174
    222-225
    420-470
Share This Page
