And I'll keep looking, too!
But considering the genius emanating from Sirio, I'm wondering, if the .64 IS better, why wouldn't they choose a .64 over a .625, especially when the impedance is supposed to be closer to 50 ohms prior to the introduction of a matching network...?
Things that make you go, "Hmmmmm".![]()
007, I'm assuming my models @ http://www.worldwidedx.com/members/marconi-albums-i-10k-625-vs-i-10k-64.html are correct or close enough to make some conclusions about the issue you raise..."why" Sirio did not make the GM a .64 rather than a .625.
I've added the source impedance reports for both antennas and I think the differences may not be as significant as I may have implied earlier.
If you look close at the free space pattern results for both you may notice that the .625 exhibits a marked lowering of several degrees in the maximum angle of radiation near the horizon---even while the gain is reduced slightly below that of the .64. Is this the gain difference the CB world clamors about while claiming the .64 makes more gain?
Again we have differences here that are small, and since Sirio elected to use the free space model to make their comparisons, I would think it natural to want this angle to be at its lowest point to the horizon and sell the customer on the idea of the gain advantage noted in yellow in their manual as they are doing.
IMO, the .625 has a slight advantage over the 1/2 wave and the .64 wave. I'm just not sure how the real world results will work out with the Gain Master. I believe a lot of guys will be looking for "on/off switch" kind of differences, and then I think there will be some complaining.
BTW, I tweaked my 22.6' foot 5/8 wave down to 20.8' feet and it shows a 4% increase in gain over real Earth to 3.77 dbi, and in free space the maximum angle went down from 18 degrees with 1.91 dbi gain to 10 degrees with a 1.94 gain, so maybe you guys with 5/8 wave antennas might try and tune them a little shorter...rather than going longer.
