I've always heard that Sirio didn't make the most 'robust' antennas around, they were sort of 'barely adequate' mechanically.
(and naturally, you could always make it 'better' by painting it pink...)
With respect to power handling on the Gain-Master, it is only 1000 watts PEP. When my sample arrives in about two weeks I'll be able to determine how difficult this antenna is to take apart. I've already though about how to increase it's power capacity if this is possible. Depending on the room available inside the radome, one might be able to replace the cap with a small doorknob or at least a Semco metal cased mica.
I suspect the internal coax may be limited too. My first thought was just replace it with some Teflon coax but then I thought about possible changes in velocity factor effecting length that would need investigation. I'm also curious if W5LZ's 5/8 wave vertical was fed in the center with the coax choked off like the Gain-Master? It would appear this is the trick for the lower TOA.
"Sexy" is right! I'd buy one just because it looks so cool and NO RADIALS!!!Especially if it provides a 'wopper' of a signal! - Ah oh, in bad taste. :blushing:
Marconi, I believe the dip you're seeing in the center might be the current phase beginning around 67.5° then crossing 90° as if they have phase-stretched the center between two ¼ wave elements where they have added the center two 1/16 wave lengths (1/8 wl total) required to have 5/8 wl instead of only a center-fed ½ wl.
...I was just surprised to see that dip in the 5/8 wave dipole model I made using Exnec...
Try an end-fed 5/8 and see if you still get that center dip in the current. It should show a perfect 1/2 wave current node over a 1/8 wave reverse current node.
Getting rid of the reverse current node by driving and phasing it as have Sirio is possibly at least partly why it attains a lower TOA in comparison to an end-fed 5/8, and why I feel the Penetrator may have it over most 5/8 as it is a full .64 plus the elevated radials may peel off the strongest part of the bottom reverse 1/8 wave current helping both the gain & lowering the TOA.
Conjecture? Yes, but seemingly performance proven.
