Yaesu FTM-350r mod - first on the internet!
Thanks for the writeup! Worked on a shiny new 350AR, and wow was my heart beating with the thoughts of breaking it in the back of my mind... (I haven't SEEN a soldering iron since jr. high shop class, and let's just say we never touched anything even remotely as small as that resistor...)
Up and running after a quick download/re-upload of the config from the radio.
350AR Mod reprogramming.
I'm considering the 350 and described mod. Once modified, will the programming software allow you access to the extended tx freqs or do they have to be input directly into the radio? Same question for the vx8 dr. Thanks.
Sorry, missed this question.
You can put the frequencies in using either software or direct entry on the radio. Same with the VX8
This is great info. Anyone know if this works on the FTM-350AR? I have ordered the AR and should be here by the end of the week. Just wanna make sure this is still relevant.
Appreciate everyones time and input.
Thanks
Thanks
Yes. They're the same radio. The AR has the firmware updates from the factory and a different mounting bracket.
I just picked up an FTM 350 AR. Any way you could detail how you did it since it's differnet from the R??? Thanks
They're the same radio internally. The firmware on the AR is updated (you can update the R version to the same firmware) and the AR comes with a different bracket. The mod is the same.
I wish I could agree but there is a big difference from the the initial post. I am trying to find like components but.....If I take a picture, you want to look? I will anyway.
what is the little switch inside on the front left corner? ....
its switched to normal but if you flip it it says prG on the circuit board... here comes a photo....:
Write your reply...
    28 days to HAMVENTION :love: :coffee::LOL::cool:
    20 days to HAMVENTION!!! :love:
