The TX coils are still "false peaked" at 22 MHz, from before hooking that jumper back up, either to the center leg or end leg. Have you tried to repeak them to see if you can get it back to 27 MHz ?
Yes I tried returning the coils can't get to 27 MHz. Did not gain any headway by hooking the coil up correctly. I am now thinking about pulling every transistor and in the transmit section and checking them one at a time. I remember this radio used to work once in a while in SSB. Now I get a carrier at the same 22.7 MHz.
