My Humble 11 Meter Station
Let's see, it's on the desk and has a thermometer built in.
Must be a plate warmer.
The label in the lower left corner, indicates what it is, as well :)
Also, it's a signature model, as indicated by the scribble above said label. :p
  • Haha
Reactions: TM86
Ahh garage-built amp? I never found the need for an amp so I don't follow the different amp builders. Nice setup
Actually, it's been nothing but headaches. I have been getting numerous reports of my Radioddity QT 60 sounding crispy on SSB, so I sent it in for warranty repair, and they cannot find any issues with it. I thought I had a bad power supply, so got a new one. Same issue. I'm using a 75A HP power supply, and I get constant reports of the audio sounding crispy on SSB, and almost everyone asks if I'm using an adequate power supply.
Not to mention the other issues I'm having.
Maybe it's coming from your amp ?
I hope someone knowledgeable chimes in to help you. I'm still sorting thru my issues but most of mine is this stinking valley. And not dedicating a life time to the radio hobby doesn't help !
Reactions: AK #5
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
