Base Q about Sirio
Greg T
WDX-945 (Jazz Singer) Upper Peninsula of Michigan
Sep 18, 2014
1,357
2,363
273
71
Escanaba, Michigan
Can someone clarify this for me?
  • 1000 Watts (CW) continuous, 3000 Watts (CW) short time
Is that 1000 continuous like an AM carrier? Or is that PEP??
Reactions: Alexis Mercado
Alot of them speak their own language don't they? It all ends up in the same place tho.
7 3
Reactions: Greg T
<<Duh, memory lapse.
Greg, don't you have a bit of property to play with ?
I have some wonderful solutions for 140' point to point. It's just that not everyone has trees, towers, flagpoles ...
I don't. I have a garage at the rear of the property, but nothing in the front but grass and sidewalk. At one time I had considered a full wave dipole, but them I'd have to drive a pole in the ground in the front yard. LOL.
Reactions: Crawdad
Perfect. Put some plastic clothespins on it and tell the neighbors it's a clothesline.
I don't care about the neighbors. No HOA here. But we do have a few kids in the hood and I'm not sure I can trust them to leave it alone. But I've always had this idea abut a full wave. Don't know why.
Reactions: Crawdad
I know, but that's not my question.
There is simply no need for 1000W or even anything approaching. It's a load of crap using it with any monopole CB antenna. Yeah sure you'll be heard far and wide but you're still only going to be receiving a short distance so you'll never hear most of those who reply to you.
Put the effort into the antennas so you have an ERP of 1000W-3000W from the antenna, transmitting a tenth of that out of the radio. You'll then find you're also able to hear most of the people who reply.
Reactions: DXman and The DB
Um ... What part of "That's not my question" confused you? I was simply wondering what the manufacturer intended as a power rating when posting these numbers. It seems there are many unexplained or debatable claims being made by manufacturers these days and I was just inquiring for clarification. Nothing more.
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
