11 meter is very quiet?
Oh, forget the say that the antenna I am using today is the vertical dipole I made out of two mobile whips mounted to the balcony with the feed point about ten feet above ground, that's how hot the band is.
(I also worked Japan and South Korea on this same antenna in the last week.)
Work them radios boys, the dx is hot, it is noisy, but if you dig there are stations out there and some rare dx to be had.
Decided last night to golden screw driver my Uniden PC-122 to get it ready to run with a little amp to try replacing DX 979 in my Expedition. It's been running all day in my radio room and sounding good and steady. Maybe tomorrow I'll get to try the transmit portion before I do the swap out.
Planning on being on the air tomorrow starting around 9am and off and on throughout the day on 37 and 38 LSB, hopefully the conditions will cooperate that I can make some good DX contacts and maybe talk to some WDX members out there , Wishing all of my WDX brothers out there a wonderful upcoming Thanksgiving holiday!!!!!
73's
Well the band is really buzzing with activity this morning,so far I made contact with,876: United Kingdom and
had a nice little qso with 553:Codeman who is traveling through Arkansas, finally was able to get a WDX member out there.....
hope everyone has a great day ahead!!
73's
73's
It was good to hear you as well. You had a good signal and audio my way but it started to fade a little. I like the sound of your Delta mike. I am running a Stryker 955 into a worn out 4' firestik. I am located just east of Ft Smith Arkansas. I was broke down 2 days and now waiting to load something tomorrow. 73.
Thank you for the contact, I love the M2 Delta Mic,I have had nothing but compliments from other operators out there on my audio and I highly recommend it,if I may suggest you might consider replacing the worn out firestik with a Wilson 2000 trucker antenna,I bet your signal would be even better than it is now, just a suggestion, I used to help out at my local CB shop when I was in high School and I remember that those were the go to antenna for truckers left and right at least in our area,you were sounding pretty good other than the other stations and qrm, have a great day today,Safe travels and Happy upcoming Thanksgiving!!
73's
