11 meter is very quiet?
I found a Kenwood 9R-59DS for 160 dollars, is that a good price?. Looks very cool, i guess i would use it to listen for short wave radio
Reactions: Rwb
That 9R-59DS is only a receiver. It's also more than 50 years old now, so even if it works you would likely have to recap the entire thing. If you are going to go with used equipment I wouldn't buy anything more than 25 or so years old as anything older than that will almost always need repair or service of some kind before it can be used.
ah, ok. too old
So.. today isn't expected to be terrible on 11 meters. Hopefully I'll get some radio time in after work today. We had rain move in last night as well and will be here for a few days.
Reactions: Rwb
Playing around with a brand new Anytone 6666 today. It's eventually destined for my Rav4, but I've got it hooked up in the shop for a couple days to check it out.
Worked perfectly right out of the box. The only changes I made to the stock config (other than the conversion to 11 meters of course) was to turn mic gain up to 34, turn off the PA function (I'd never use it), and setup the SWR protection. Running with the stock mic.
Amazing the number of contacts that can be made with just a 45 watt radio !
  • @ W4KVW:
    Rock Stars ROCKS!
    Looking forward to it Gary!
