2995dx amp switch install w/pics/questions
well its took me a while but i just got a new"less than yr old" rci 2995dx with the green digital face..sadly it came from a good friend that passed away last yr so i traded his brother out of it..got about 400 into it so not too bad..
decided after reading for 2 nights to install a switch in the amp section for lower watts as i talk to guys in my n.hood thats real close and also dont wanna start over just yet with new amps..i like my ole tube amp that i hardly ever use.
really have no need for a amp with this radio either..it walks the dog..
i read that on the older 2995dx units folks says they run the switch on a brown wire that plugs into the back amp circut board in the right corner..i have a small plug there but its yellow and green wires..
the new mean well power supplys have a row of wires on the end and all labeled so i used the red"hot "wire coming from the p.supply going to the amp and switched it in that wire. IS THIS OK ?
im asking because i just finished it up and everything is working fine with it on,but dont wanna turn it off till i no for sure why folks say use the small plug on the board to install the switch? they say this about the older ones far as i been reading..
so me cutting the power at the main hot lead to the amp should be the best thing to do id think..comments welcome,except how 4 watts is the limit and im an outlaw<can not stand it> the first pic,red wire on the left it the one i used,and i fused it also with 20 amp fuse and used 25 amp switch..had to use a white wire as i was out of red :) thanks,and heres some pics of the radio and switch install,j9
I know this thread is very old. Did you ever figure this out? I think the green/yellow wire is the trigger for the amp. That's what I think should be switched.
The wire colors change when the production design is revised every few years.
Pretty sure you'll find the green wire is "hot", where the switch should go. The other wire is ground.
Don't remember seeing one that had the two wires the other way around.
I know this thread is old, but on the topic of questions I seek.
I have an older orange 2970. With the amp switch off I get 1~1.5W deadkey with 8 watts swing. No other swing mod or anything has been done. Is this the wattage to expect due to limitations of the single final ?
Thanks for the education in advance.
Lol wow I don't remember posting in this thread ten years ago. Must have gotten a little wound up about it. That said I do like Nomadradio's theory on this kind of a mod. He does it but calls it the suicide switch.
We adopted the habit of removing the tiny circuit board from the rear of the headphone jack and inserting a LED from behind, deep enough to see when it's lit. The ones sold with a resistor and wires already installed are easiest. This requires a two-section switch, one side for the LED one for the amplifier's relay wire.
Yes, you have to jump two wires that came off the headphone jack to make the internal speaker work.
The LED makes it harder to forget which way the switch is flipped before keying it with any kind of low-drive device in line.
I posted a step-by for the Stonewall Jackson base, but not for the 2995DX.
Just can't remember which of the two wires is hot and which is ground.
If you have a multi meter, set it for continuity and clip the black wire to one of the metal shields for a ground connection. Now poke the probe onto each, the green and yellow wire where they come out of the tiny plug. The crimp contact inside the plug should be just barely accessible to the tip of a probe.
Only one of them will show continuity to ground. Your switch goes in line with the OTHER wire.
    GlocknSpiel has left the room.
  • @ kingmudduck:
    So I have a cobra 138xlr and the meter dose not work... It dose not key up and signal dose not work.... It is not stuck it the meter moves freely. now wires are resoldered on both ends...So now that do I look at. Could it be a diode or a transistor?
    Greg T has joined the room.
    Greg T has left the room.
