Well I had the opportunity to go over to Warren's place (VO1KS) on Sunday to have some mods done to my Larcan amplifier module in an effort to increase the efficiency and lower the drive requirements on 6m. Basically it involved installing several SMD type capacitors on the input splitters as well as the output combiners.
Extra caps added to the main output combiner out to antenna.
Extra caps added to the combiners that combine two output modules into one that then feeds the main combiner in the first image.
Several more caps added on the output of each of the four MRF-151G MOSFETS.
The long trombone shaped object is not a wire. It is a piece of semi-rigid coax cable that is used as part of the tuned circuit on the outputs of the FET's. One piece had to be replaced as I had a little accident that was not noticed until we got on Warren's work bench. The cable was pinched to the point of actually shorting it out.
In case you are wondering what kind of size we are dealing with here is a picture with my scale showing the size of the caps and the coax cable. each division is 1/10 of an inch. The caps are basically 1/10 inch square.
When we started we had 5 watts of drive and 500 watts out with 38 amps at 50 volts. When we were finished we had 5 watts of drive yielding over 700 watts output and with just 7 watts drive we had a full 1 Kw output with the same 38 amps at 50 volts. The overall efficiency when we started was a dismal 27% but a respectable 50% when we finished which is about all that can be expected without a huge amount of more work and then the increase would only be minimal. Being clean class ab 50% is perfectly acceptable.I may be QRO on 6m this summer after all!
Speaking of QRO, Warren remember the question you asked me standing in the doorway of your garage? The question about the tube? Look what I found in my shop while looking for other goodies. I found another one that had a removal date on it (I forget when) and the notation. "Still makes 1.7 Kw". It was used in the QEI-3500 watt tx in Weymouth. That tx was limited to 2500 watts at the factory to increase it's efficiency at that power which is where it was normally run. I thought hmmmmm when I found it. When I pulled this one out I though holy crap! IT's NEW!!! Then reality sat in as there is no way i would have a new one but only maybe a pull or two. It does look super clean and shows no inter electrode shorts as far as I can see with just an ohmmeter. The ceramic as well as the silver plate looks REALLY nice and clean. Too bad I didn't have a test jig. LOL. I may have to speak to you again regarding a socket.
