Use about 500 feet of RG-58. You'll have nice, low SWR even with no antenna connected!
lol
Your choice.Should we tie a knot in the radiating end or leave it open?
This generally helps with the absence of sufficient counterpoise.
I had not even thought about that... now that you mention it, the 8 foot pole would not be enough would it...
Don't think 20' would do it if the coax doesn't, not sure the base is connected to anything other than the coaxes shield which makes it the counterpoise.
I could test it by connecting a wire to the base of the mast...
OR I could isolate the mast from the antenna and connect the GPK... BUT it is missing 2 radial... I could just make those out of wire... so 2 would be wire and the other 2 would be OEM
OR... I could just isolate the mast and the antenna and use 4 69-72" long pieces of wire and form a new and CHEAP GPK
the a99 is a 1/2 wave so you only need about 24 inches of radial. if you can fabrickate a hub try using about 10-20 24 inch radials (like the kit he used in this video) just below the rings conected to the aluminum mounting tube to decouple the coax then retune it untuil your swrs are flat
well the 4.25" 5 turn choke did the trick... max SWR is now 1.25 in the CB band and it stays under 1.7 a band up and a band down
Boomer Ground Radial Kit fitted on a Shakesphere Army Big Stick CB Radio antenna. - YouTube )
