After much trial and error and some tuning me and a buddy were able to get the Connex FC-390 working on the front mic Cobra 148 GTL successfully. It took awhile and some tinkering but it is working.
However , I have encountered some strange problems since it happened. First of all, my RX seems way down. Generally when i have the radio on and am listening on 38 LSB there is a considerable amount of blank static white noise that i will have to turn my clarifier up in order to hear. After the install I am able to tun the rf gain ALL the way up and barely hear any static. This concerns me a bit as I love shooting skip and wanna be able to hear all the stations out there during peak hours.
My second issue....When installing the counter I looked through various "guides" i found. SOME stated to use a 68pF ceramic resistor at the end of the white wire that connects to the VCO, SOME stated it wasnt needed and some stated that you didnt even need to use EXACTLY a 68 , that using a bit higher would even work. I was never able to find a reason for this resistor and what the effects of using it/not using it are. We ended up only having a 100pf resistor on hand and used it. Can someone shed light on what that resistor is for and if it may be causing my RX issues. And if not, any idea what could be. Once ive solved this little issue with RX I will post pictures on the exact places on the front mic PCB version of the Cobra 148 GTL so others can successfully do this mod. Thanks!
