I know that I have seen tons of videos where people run their radios from old/used PC server switching power supplies. A lot of people say they don't see a noise problem, some say they do.
have any of you used one in radio service and, if so, what was your experience?
The reason I am asking, hook line and sinker..... I just picked up a used HP Server power supply on Ebay. This particular model is "screaming easy" to convert to 13.8V DC (snip & jumper OR....just jumper bypass a single 100 ohm resistor...and adjust the max voltage pot! This model is WELL KNOWN to work this way!
When done it will serve 13.8 VDC @ about 50 A max. I won't be using NEAR that.
The supply and shipping totalled $21.42 and I saw that as "worth it" just for the try.....
