Anytone Ares 2
This new revision has an unusual layout from what we're used to. The features are nice indeed but placement of them is odd.
I think I'm more for the quad 6 plus but that's just me.
Reactions: Pez and 2AF409
How's the noise floor? Does it compare with other radios you have on the same antenna? When you adjust the clarifier does it give some sort of + or - indication on the channel display (like the Q5N2 does?)
Noise floor is good, seems quieter than my President McKinley EU. Clarifier is by ear.
I will say it is very easy to use, it’s like using a classic radio that has the newer features. They did a good job of making the features accessible without making the radio complicated. I think that will appeal to a lot of users.
swr on the ch indicator when you tx is pretty cool. the mic does menu functions etc so i wonder how easy it is to put a regular mic on it (astatic etc)? i want one
The noise reduction on tx is a noise gate, I believe. The Stryker 955 and KPO DX5000 both have the noise gate, which is why I think this. Works great if you have a fan running in the background, cuts it out completely. Have not tried it mobile, but I bet it would work great there too.
Reactions: TIN_CAN
hopefully someone figures out how to get into and the functions of the service menu soon as well so the output power can be adjusted and the modulation/deviation can be adjusted as well.
Have you received yours yet? still waiting for mine to ship from the Alibaba.
I've now read about 5 differant forums and everyone has said the same thing that the radio should have had a frequency counter in it like pretty much all radios now have. Pretty dumb radio the way it is no matter the TX or RX.
Reactions: L2
No, it's basically the same NRC as the AT5555Nii - RX and TX NRC, adjustable from level 1-5. (The best type).
