Anytone At-6666 Pro
It is happening. And it will be available soon, along with new firmware to support it.
I was told about the FW, but was told no ref osc adj for user, just "pro". Maybe they changed their position? I don't know or care. 20 Hz frequency error is nothing on any mode the radio supports.
Hi all,
I have just posted an update on a new AT-6666 PRO firmware update, PC Alignment (service mode) tool, and PC software here:
73,
Pez
Hello!
I'm new to the forum, I just bought an ATQ6PRO radio. I made a cooling fan with control. I did not drill the radio anywhere, if necessary, the fan can be removed. I set the control so that approx. 37C heatsink temperature with this solution.
The controller is very simple and cheap.
I hope I was able to add value to this community.
Sorry for the bad English, Google translator was my friend. :))
Greetings: Csaba from Hungary
  • ATQ6Pro_ventillator_vezerles.pdf
That being said, it is pretty easy and straight forward to flash if you get/have a radio with the older firmware. BTW, the QT80 & Q6pro Firmware is slightly different (display name).
What do you mean by "display name"? The name shown in the QXCodePro3 firmware tool, or something else?
I think he means the default power up display.
Yeah, except these AT-6666 PRO / QT-80 radio's don't have a power up display at all.
(The AT-5555N2 and QT60 / PRO have the configurable display text, but that is programmed with the PC software, and is not stored in the firmware either).
I was guessing. My crystal ball broke, so your guess is as good as mine.
Reactions: Pez
Hello!
I would like to try an amplified dynamic microphone with the Q6PRO radio. My question is, how can I connect the PTT wire directly to Gnd? Or do you need resistance?
Tnx!
Reactions: whiteastro
