1000w AM PEP
If I understand it correctly. Is 4 x 250W RMS. A Palomar Skipper 300. With 1x 3 x short
6LF6/8950. 3.5 watts to 4 in. Dead keys 300w RMS. AM PEP is 1200w.
Most likely. The original band this Amp was configured for. Is not 11 meters.
The Skipper if I remember. Is about 800v DC under load at the plate.
The no load voltages. Or "Peak" voltages are always much higher. Skipper uses 3 x
450v in series total 1350v. Higher than the peak.
Sweep tubes are getting pricy. 6LF6 is very pricy ! So running conservative is the way to
go for most people. I think. Like the Skipper. Your box is not chained to 6LF6 for FUEL.
A separate filament transformer makes them versatile. Simply swap them out for
whatever 12 pin Beam Compactrons U may have. 20LF6, 27LF6, 26LX6,
30KD6,36KD6,
30MB6. 8950(13v) which is the same as 6LX6(6.3v). Even M-2057. LF6 is really the
best though.
Up to 1.2 amps at the plate. 40-50 watts plate dissipation. M-2057. I am not a 100%
sure it is actually a compactron version of the 8908. 2.5 Amps at the plate. Easily 50
watts at the plate. I will find out one day. 30 M-2057. But no 8908 ugh.
I cannot tell how large your plate transformer is or heavy. U can estimate the KVA by
the weight. Push 3.5 W into it ? The Skippers will do 450w RMS with 8w in.
With 6LF6 this was not an issue. Anything else EG 8950 LX6. U have to keep the keyup
shorts. So U don't black toast the tubes. Even with 6LF6. It had to be short. The main
iron would short out & be destroyed.
Have fun !
4fingers&aThumb
Ah didn't notice your question.
When I go about the Art of fabricating RF tank coils.
I start with my favorite frequency. 27.385. Sweep tubes especially LQ6. Are notorious
for there low output impedances in parallel.
To directly answer your question. I personally am uncomfortable with a Load & tune that
are Maxed out in any way. I keep playing. Until I arrive at full output. Additionally.
I have to see play in the load & tune variable capacitors. Circuit Q ought to be very close to 12.
The main tank coil minimum Q of 10. Maximum Q of 15. I do not use solid wire. 13-14 seems to be
optimum for the sweeps I have played with.
I use 1/16 OD up to 3/8 OD tubing. Nickel or silver plated.
Its possible to have several different Tank Coils that will work. Only one. The right one.
It will have a large frequency tuning range at Full output. Driver tanks ? I've read from the
Ham guru's. A Q of 2 ? My experience with Sweep tubes says different. But. the Hams were working
with very large triodes & tetrodes & non Beam pentodes ?
If U R getting 250W RMS. 2w in 700v at the plate. Assuming it does this from channel 1 to 40.
Sounds about right. Without a good Inductance meter. LCR. It is nearly impossible to fabricate RF
tank coils for Sweep tubes. It can be done. If you quit your day Job ? trial & error ?
4fingers&aThumb
