hi all..
came across someone's idea of making a dipole for the attic using 2 firestix and wanna give this a try seeing i have two 4'ers sitting here collecting dust..
the only thing i didn't see mentioned was a ground? seeing as it was just being mounted to what appeared to be a 2x4 in the original plan am i to assume that the only ground being utilized it the shielding in the coax and the radio? is this the best option or should i be looking at something else to ground the bracket?
A Stealthy Homebrew Vertical Dipole Antenna Using Mobile CB Antennas
thanx
thanx
