211, if them guys at Sirio had given us 6" inches more material in all of their tubing lengths...the point Bob is making wouldn't likely make any difference. Personally I think sections 2 & 3 should be 70.875" inches each, and that would give just a little bit more overlap for #4.
But your little error noted earlier...might just be the difference in success and failure like Bob suggested. As you make sections 2 & 3, a little shorter that they should be, you will be inadvertently be making section #4, sit inside of #3, with less overlap by the amount of your error x 2.
I wish I had checked and recorded this top element overlap. Maybe you could mark you antenna when you get the wire stretched out like Bob suggested, and tell us how much overlap you get for #4 element.
I figure the overlap should be about 4" inches when the antenna is properly setup.
Good luck.
