Donald, I have to say you guys are consistent with the bias that affects us all.
My lecture for the day.
I think what 211, just reported here is the same sorta thing you and many others go nuts over repeatedly with me. When old Grampa reported his signal reports you didn't like what he reported, but you really didn't know exactly what he was doing either. When Grampa started doing his video's to help support what he saw on his radio, and support the paper reports he made just to help those interested to visualize in real time, where you actually saw what Gampa was doing, y'all went even more berserk and those events clouded your thinking even more.
You guys were no longer even trying to be objective regarding other ideas...except for your own.
I and 211 were just CB'rs doing what many CB'rs do with the tools they have to work with.
I have reports of talking to San Antonino, 200 miles, Waco 125 miles away, St Augustine on the Louisiana border 200 miles away, Bridge City, Louisiana 200, miles away, Franklin over a 100 miles away, all over Central and East Texas, and I don't have any trouble unless I can't hear a station. Over time this has happened with all my antennas up and one time or the other, and I have never realized one antenna was making a copy while another was not.
At times I do hear a little difference, and at times that difference is in the range of full copy vs. limited copy. But, I had enough sense to realize those events where at relatively low signal levels where the contacts, at best, where possibly in the typical noise level at the time...and for the particular antennas on the other end of my switch. Which was better or worse was a matter of hearing is true, but in those cases I most of the time could not see and difference in the signals...they were both in the average noise level.
I assume you are referring to contacts and signal in the outer ranges of the radio signals, right?
Those signals are often somewhat abhorrent in my opinion, and that is why I average my signal reports using the same contacts when possible, try and get as many as I can at the same point in time, and try and provide some details about the contacts location on my reports, but you smart folks out there just ignore the added info my reporting could provide, because your bias that says NO, is blocking you judgment...or else you would have automatically discounted 211, honest report...just on the grounds he used SSB.
You guys don't fool me one bit.
You did good 211.
