Budget Base set up
Well I did get it working, but there is too much lag after you hit the TX button, takes a couple of seconds to switch to VFO b transmit and back to VFO a for RX. It probably has to do with the poor com port routines and all the extra software like virtual com ports that I had to install to get HRD to work with the Rigblaster PnP ..
I just started reading up on the serial stuff included with the HRD, gonna experiment with that and see if its ant better, or even works with the RigBlaster PnP.
I do have a nice set of cables from the guy in England but I dont have a good USB to Serial converter, the one I have is a prolific chip set and its nothing but problems with HRD.
Here is a pic of me on the roof doing the final install.
Here is a link to the NA1SS Contact !! http://w1med.net/blog/media/blogs/a/elkantenna/NA1SSdeW1MED.mp3
I think the Wouxun USB programming cable uses the prolific driver, the cable works on my XP laptop but doesn't on my WIN7 laptop. Wouxun.com does have an updated vista/win7 usb driver listed(8/10/2010) that may help even with your HRD issues.
Nice recording with the ISS
Link to new USB driver: China Two Way Radios,Handheld Walkie Talkies & Interphone
I gave it a try and get the Blue Screen of Death, this is an old Prolific unit, I will try to find one with the FTID chipset.
I'm not real happy with the rig blaster, I have to make adjustments almost every time I key up. and I always get 3 bars of ALC no matter what the settings, could be the sound card, so I might try an external USB Sound card.
Thanks
Craig
An actual physical serial port may be needed, I know from experience at work that a lot of the USB/serial converters aren't what they need to be. For a laptop it would cost over $30 outside of ebay for an expresscard serial port.
Here is an old post from QRZ that I posted to just to be able to find it again, turning down the buffer on the USB/serial might help
http://forums.qrz.com/showthread.php?t=182145
Ok so the Budget setup has taken on a life of its own and gotten completely out of control.
I now have a 25' Tower, a Yaesu G-5400B AZ/EL Rotator, a Gulf Alpha Dual Band 6' Yagi on order, a Fox Delta Computer control Interface and I just bought a used FT-847 Satellite Base Rig ...
So much for the Budget Base system, but when its all put together this should be a Great Satellite base system.
I'll start a new thread when its all together and functioning as well as a lot of new pictures.
Ok Time to go up the tower and get the rotator mounted.
Craig
