There is such a beauty in this thread. The consistent looks into the issue of making an antenna work - radiate - so others can hear you.
@M0GVZ - nice segue into a topic that not too many have touched on. Radiation Resistance, or "how to make your antenna Emit more radiation". Shorter antennas don't do this as well as the larger, longer or to read this as Elements with larger Surface areas to radiate signals from.
How can you tell?
Well it's simple physics as well as just common sense
Consider the ISOTROPIC - talk about quantum theory - look at the period at the end of sentence.
Even then, that "dot" is only representative of the theoretical
You can cover the dot. But the properties remain.
Think about the Dipole - 1/4 over 1/4 - a line into two segments - fed in the middle. One works the other.
Now you have a working element in space - you're occupying a volume - you have surface area in which to radiate a signal.
Compare it to a streetlight.
From a simple distance, you can cover the bright glare of the lamp with you hand. Maybe, just maybe - see the halo or reflection - glow of objects reflecting the light from that same source.
- When you're really close to it- you cannot truly remove the light from your view, even by closing your eyes, the eyelid is thin so the light can shine into and thru it as you see it still - only without shape or focus, just the light thru the layer casting a filtered light into your eye.
Just understand the concept of blocking the light and seeing it's ability to shine out to other objects - brightly enough to let your eyes see the objects being illuminated by the source your blocking. Again, a light is a form of electromagnetic radiation - you have a source which then radiates outward, only to be reflected-to illuminate the objects that block or cast a shadow behind themselves - eventually the light can no longer "illuminate" and provide enough reflection -energy to reach your eyes - it simply fades into a spot of light, if you walk away from it.
You can still see it, but as you gain distance away, the objects that come into the way of you from the light source, casting the shadow, are now placing you into that shadow of the cast light as well.
- If you make the light "bigger" by increasing the size but not its wattage or energy - you lose the brilliance but you use that energy to radiate from a larger surface.
- You can then take it's energy to spread across the surface area of the "diffuser" to even though you lose the "glare" you can still see light emission from that surface - which didn't exist if you only used point sources of light. The Shadows are not longer so contrasted against the night.
Same can be applied to the Radio - the Electromagnetic radiation spectrum still uses those same properties but now the waves or radiation can reflect or otherwise diffuse into the ambient level of radiation - you can then filter it out like you do with sunglasses - even polarized, to reduce the softening effects of the various angles in which the light arrives to you. IN fact - polarization of sunglasses are pretty much what you are doing with the antennas you use to both radiate and the reception of the same.
So - keep the conversation going - just wanted to make an observation (SIC)
