CHANNEL 16/SSB
I just use my regular numbers nothing special hotrod. I call cq dx 222 Daytona beach, FL. I'll be listening today at the designated time. Hopefully we can get the conditions to stay going!! And keep the Mexicans from blasting us!!
Reactions: midnight special
well heard someone come in and was apparently talking local,,, said they were testing amp out lsb,,,couldnt hear who he was chatting with and i reckon he couldnt hear me either,, otherwise all i got until full dark was spanish amers which i think one is a dispatcher of somekind......will be back on sunday evening 6 to 8pm maybe time change will make things beter.
It is loaded here, I just turned it on. Most of lsb stations I hear are FLORIDA and the WESTERN states, although I cannot say much for the EAST COAST, skip hasn't been that way for ages.
DOCTOR/795
I'm wondering if a different time slot would be better. There would be different propogation characteristics at play. Earlier tonight, I did not hear a soul - local or DX - after 6:00P.M.
But it was a spectacular, picture perfect, Chamber of Commerce, blue sky, 80 degree day down here.
Same here Rick!! Not a sole to be heard. Thank god for my locals!! It really died around 5-6 here as well, (central FL) but at least I can rag chew with my buds locally. Maybe a different time slot may be necessary. I will have to do some research and see what times appear to be good on 16lsb. I'm sure it is like what every other Channel is like but I will research anyway. Will update.
spanish for a while, then it quieted down about 5pm,,, after 6pm nothing i called for about an hour and gave up...last night would have been a good time for ground wave,, talked from central florida to cape caneveral and up into clermont easy,,,,
  • @ Geoexplorer69:
  • @ Geoexplorer69:
