My 40D apparently did come from a smoker, but I doubt it made it that brown, haha. I'd have to open it up again and see what numbers are on the main board. Maybe it was swapped out at some time. What site 399? Thanks.
You mean the mylar?
So the board marking is wrong....looking at coupling circuits, the schematic is right.
+ in / - out
more soldering.
Also that regulator is a 2SD188.
Anyone know what the next beefier one is? Maybe a TIP2955 would be better?
I've been trying to nail-down a kinda "crunchy" sound in the receive audio.
I found if I put my finger on pins 3 and 4 it eliminates the high tone "crunch".
I was wondering what this green insulated wire was from ground to ground over the pins.
I think they are using this to give some capacitance or something.
I rearranged it closer to the pins and it helped quite a bit.
I also added a 10uf cap from pin 3 to the "isolated" ground...helps a bit more.
yes the soldering looks like crap cause I'm still experimenting, I'll clean it up later.
I find the power supply is still getting ridiculously hot.Yup ... I should have said mylar. The regulator pass transistor 2SD188 is rated at 10 amps collector current, 200 Watt dissipation. Subs to an NTE 87. It should be more than the radio will ever require.
- 399
Ya I guess thats what I'll do.What is the final filtered DC output? 12-14 VDC would be appropriate for a stock supply when transmitting. There is usually a potentiometer on the power supply board that can be tweaked up a bit if needed.
Put a true RMS AC meter on the filtered DC output and check to see how much (if any) AC ripple is present. Less than 1/4 volt should be okay. I think you said you already replaced the power supply filter caps right?
I tend to use my external 15 volt 100 amp power supply when the CB base stations come with the standard 3 pin power jack option. Fuse the power supply wires accordingly. You will loose the clock function (or synchronous motor) when not hooked up to the AC line but there is no question if the radio has enough supply power with 10 amp or greater PS running at 14.5 VDC. Sometimes audio problems, weak output, low modulation and flickering light issues go away magically.
Nope still flickers.replaced tr301 and tr302.
Seems to be stable now, got the voltage down to 13.8
I'm still gonna use the external anyway cause the internal one gives off too much heat and it gets the radio drifting.
I find the power supply is still getting ridiculously hot. I get 24vdc out of the bridge, that ok? I'm trying to think what part would cause the power supply to run hot?
Is the TF-086 just wimpy? I see the 2000 used a TF-164
The cobra 142 looks a bit wider too. View attachment 17721
Thanks for the advice.24vdc out of the bridge is exactly on spec. The unit draws about 0.6amp in both AM and SSB receive (normal volume). With the rig set at 4W AM, and 12W ssb, it draws 2.4 A Am xmit w/mod, 3.3A SSB w/mod. The stock 40D transformer is rated at 19 vac @ 4.2 amps, so it should be stout enough. FYI, the 142 transformer is rated 17.2 vac @ 3.8A. The 2000 is 19.4 @ 4.8A. The best is the transformer used in the 139XLR which is rated at 20.0vac @ 5.4 A
Is the unit getting hot in xmit or in recv?? Or all the time. I checked my 139XLR after about 15 minutes on the air, and it was pretty warm, but not so hot I couldn't keep my fingers on the regulator.
Disconnect the pink wire going to the emitter of the regulator pass transistor (TR303), connect a milliammeter in series, and check the current draw in receive. It should be about 0.6A. You can check it in xmit using the specs above, just make sure your meter will handle that much current. Good luck & 73s.
- 399
