doc, this was the statement from your post that prompted my statement about which side of the fence you reside on.
if i am mistaken in my understanding of this statement, and you actually do enjoy the sound of a slightly overmodulated high-level AM signal, then i rescind my previous statement.
i do not dispute the truth of your post, but i do feel that it is you who has misinterpreted what the question was about.
he did not ask how to make his signal look good on an O-scope; he asked about the best drive levels for his linear amplifier.
you did not address the question, and instead assumed that he would want to know about how an AM signal looks on a scope and why.
in this regard, you missed the point.
were you wrong in your post, no, but you just confused the issue.
in doing so you sidetracked the thread, and left simbalage befuddled about the point of your post.
i merely brought the point home by stating that its a subjective argument as to what sounds good to who.
and BTW, i was just messing with you a bit. loosen up.
hijack over.
Well I didnt realize my thread was indeed hijacked and dont mind, as all knowlege relating to the issue does help.. I was a little confused which is why I asked. My main point was indeed to make my radio the loudest without overmodulating the crap out of it whereas I hear some.. I talk to wife at home from car and want the most bang out of both, without sacrificing quality too much... although I dont mind knowing what this can do on persay a dosy, real world performace is what I am after.. So I got some good responses such as 1/4 of modulated should be deadkey ect.. And 45-55w on the linar deadkey which is exactly what I was after.. Trailing down to what to do as far a deadkey/Swing with the 510.. Which if I get another linear for the base, If the info I found is correct then I should be able to use the hi Drive with a 4w Deadkey without blowing it up in the mobile.. But before i take this info and run with it I wanted to 100% certain and learn more about correctly setting deadkey for barefoot and with power.. Modulation and weather or not to cut the limiter is a matter of opinion and personal taste..
