Mt R: You being a Tradesman know this, however most people don't.
That any removable or replacement cord cap(plug) does have a specific way to be wired.
3 wire cord and plug
Gold Screw is ALWAYS Hot...Black or Red(rarely though)
Silver Screw is Always Neutral….White
Green ALWAYS...Ground/Green
2 Wire cap Should be marked the same, however if it is not....The Neutral is the LARGER/Wider Bar on those caps.
Now some cords have EURO/ASIA Colors: Brown/Blue/Green with Yellow Stripe.
BROWN-HOT
BLUE-Neutral
Grn/Yel - Ground
This applies to 120 Volt Circuits in USA.
Plus Mt. R. I mentioned the plate on the back because I have found those Jumpers misplaced.
I have seen people wire those Buck/Boost windings on the Transformers wired for 110 or 100 Volts, and not the 120 volt locations.
This is a futile attempt to get more High voltage and increase output power. Yes it will raise the HV.
However it ALSO raises the FILAMENT Voltage, which will shorten the life of the tubes.
SEE Page 4 of manual for Correct locations of these jumpers.
So just FYI check everything for correct wiring and that amp will give you many years of good service.
Have Fun and Enjoy
All the Best
Gary
PS: I only mention this due to any cord that can be wired for 240/120 needs to be correctly landed if someone has used it on the Higher/Lower voltage configuration and is user changeable. One never knows what someone else has done before!
Check everything/Assume nothing
