Export radio choices..
  • Lincoln 2+ v3
    Votes: 12 18.8%
  • Anytone AT-5555 v6
    Votes: 6 9.4%
  • Anytone AT-6666
    Votes: 15 23.4%
  • Stryker 955HPC
    Votes: 16 25.0%
  • Ranger 2950
    Votes: 11 17.2%
  • Ranger 2970N2
    Votes: 4 6.3%
  • Total voters
    64
i thought about polling same radios...lol. this was tough cause these are good one. and i dont know what ya pereferences are .i dont care for menu driven radios much . but because of the small size and output and reviews on here and locals here have one i chose the anytone 6666.but i also like the 2950 no menus and bigger display...then last i like the lincoln 2.. these 3 is what id have it cut down too.jmo
Reactions: S&W357
I put my 6666 thru the wringer today. Made a bunch of 10 meter contacts. Worked a few FM stations. It's not a RAG chew rig. I reached around and bout got a handful of blisters. Sucker gets hot quick. Rigged up a fan begind it to tame it down. So, I gotta figure out how to mount a fan on it.
Got good audio reports from everyone. One dude on 29600 seemed to act snotty once he heard what I was on.
Personally I think it is. A lot of people complain that when turned off it loses some settings...however if you save the frequency to memory you don’t lose anything. The other major complaint is changing modes LSB...USB...FM...AM there is not a button that enables you to quickly change. You have to go into the menu. This radio is heavily driven by menu’s...something you won’t be doing while driving. I believe you can adjust the AM power down to 1 watt so you could drive an amplifier at that level...I would need to check the swing to be sure.
A Galaxy 98VHP use to be mounted in it’s place..I was wanting a smaller radio with nice big display and the FT-891 fit the bill. Typically everyone raves about the NB and DNR of this radio
I think right now HRO is listing them at $599...I got a new in the box one off QTH from a trucker for $400...yes heck of a deal.
Here’s a picture of the four antennas on my truck two uhf/vhf and two 10/meters.
I'm sure it sounds great on SSB but how does it sound on AM?
I’ve come to have a strong preference of the Lincoln II over the 2950 series. Don’t know about AM - I don’t use it.
The large display on the RCI is better, but the controls are so antiquated it’s not worth it. The radio really needs a modern facelift.
But..I always hear MANY of them in international DX.
Just picked up an Anytone 5555n and it is a great radio with a big display. It comes with a real microphone, not the Fisher Price looking one with the 5555. You can see where the Stryker 955 gets its roots from too. These are real popular across the pond and people have come up with tons of mods. Its worth a look.
I voted for the AT-6666. Although I slightly prefer the AT-5555v6, the AT-6666 is a bit more user-friendly for the average user. I have both. I also used to have an HR-2510, and I like both of the Anytones more than the 2510.
I have a lot of HF rigs too, but I rarely use those for 10/11 Meters. For me, 10/11 are different enough from the lower HF bands that they deserve a separate rig.
The 5555 is larger and easier to access all the functions. It does 60 channels per bank, instead of just 40. Has a larger display and can read out both channel and frequency at the same time. But, you really need the programming cable and software to really set it up properly. There are some freqs it just won't do unless you enter them via software. And, without software you have to do the power-up sequence every time you switch between 10 and 11 Meters. With the software you can set it up so you don't have to do that.
The 6666 is smaller and fits better in a mobile environment. And while a programming cable and software are available for it, they aren't strictly necessary. There is a button that toggles between frequency and channel mode. Basically you select the channel bank (which all of these export rigs call "band"), dial up the channel (only 40 per bank on this one), then press the "FRQ" button. That shows you the frequency of that channel. Turn the main tuning knob or use the channel up/down buttons on the mic to change the frequency. Press the main tuning knob to change frequency step size.
Of course you have to initially do a power-up sequence to access export mode, but you only have to do that once and you have the entire frequency set.
You can access the entire spectrum of 10 and 11 Meters directly from the main tuning knob, even if you don't have the programming cable. And, once you change the frequency of a channel, the new frequency remains associated with that channel until you change it again.
Negatives are that you cannot see the frequency while you are in channel mode, and you cannot change the channel while displaying the frequency. Also, I would like the option of tuning a new frequency and then having it revert to the old frequency when I go back to channel mode.
One or both of those items may be available via software. I haven't really delved into it that much. In fact, I bought the cable but haven't even used it yet.
Going to give the 955 a try because I use both SSB and AM. Should be here tomorrow and I'm excited to try it out.
Initial reports seem very favorable. My locals say it's right on frequency and sounds good, I'm a sidebander mostly. Even made some skip contacts with it yesterday. I kept it stock. Very happy so far.
