The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
I just want the new capacitors installed in it..im being real easy on it to running a texas star 350 with the variable turned down to like 40 watts in it with a 100 watt dead carrier with pedal mashed down swinging around 950 pep watts
100W of deadkey into an SB-220 is a bit high. Harder on the PS and the tubes. 50W deadkey is really all it should have, max. Just let it swing from there.
552fl,
I've never done business with them. I just "Googled" it and ran across his information. Perhaps others on the Forum could answer??
If it is a "sideline" business, it's possible it could take a day or two to respond. Is there any telephone information on the web site?
Near Fort Lauderdale...SE FLA...He is a Commercial Antenna installer...
He is also a Ham (N4ZRV)...So I am guessing this is a secondary Hobby/ business... http://www.wolfradio.com/
GL
All the Best
Gary
Gary,
That's what I thought as well. I am sure he will respond to 552fl in due time. Can't imagine this is "one of those guys" I've never run across any "bad press" about him.
552fl,
Sometimes people are very eager to separate a person from his hard earned cash. Usually those types are somewhat unscrupulous. Buyer beware. Be patient.
What part of FL you located in?
Shipping charges on that SB220 and will cost more than having the work done you are wanting,
Also you will need to remove that hv tr as it can and will damage the case if it gets thrown around in shipment.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
