Curious, did you restore r176 back to stock or did you leave it with your trimmer?Just put a 10k across C158, initial testing sounds great. Getting ready to put it on the scope in the shack.
View attachment 48710 View attachment 48711
R176 still has the trimmer on it, I left it adjusted the way it was.Curious, did you restore r176 back to stock or did you leave it with your trimmer?
Yeah, not quite sure what it was. I ended up adjusting it again.Curious to know what is the value of the pot...
Off topic, but I just noticed you have at this moment 6955 likes! Couldn't let that go to waste without a comment. Anyone who is or has ever been interested in shortwave pirate radio will know what I'm talking about.Found this nugget of tuning information on the WWPDX website, where I am also a member. This is a quote from a Galaxy tech. You guys reading this should stop by and sign up. There is tons of information there.
http://www.wwpdx.com/ForumWWPDX/vie...h&sid=f349b6d393c843ec48211d7a6a74473a#p23962
As far as I can tell, the newer Galaxy radios have the double FET at L8. This includes the 86v, 959 and others.
One difference in the receiver section of our four new radios using the EPT690010Z/C boards is the addition of an extra FET in the receiver front end. While this added FET is partially responsible for increased receiver sensitivity it can also cause the receiver to be excessively noisy if tuning coil L8 is not adjusted properly. I have found during alignment that tuning L8 for a peak reading on the s-meter is not always the best method because this can increase the noise floor or sometimes called "hash" sound in a receiver. This is when a good signal generator and scope can really help but for those out there that don't have that luxury then simply tune L8 for a peak reading on the s-meter like normal. Now remove the antenna connector from the radio and then continue adjusting the core of L8 approx. 1/4 to 1/2 turn clockwise just until you hear the noise floor drop slightly. You may need to crank the volume control up for this last step.
Before you "de-sensitize", tuning L-8, get a fixed signal reading from another known station, do the tune, have them throw you a dead key, and just reset VR-1 (the 95-T's AM Meter adj.) to the original S reading you had before. Check on CBTricks.com for other model #'s to be sure....(Use non-conductive alignment tools, please!)
I thought cbtricks site went down. Do you mean the one that charges money?I read through this thread and did not see it but, CBtricks now has a section for the 86V that has the usual alignment locations and specs. Also the conversion and 10kc and hi-cut mods. FYI....
Yes it does now...I thought cbtricks site went down. Do you mean the one that charges money?
Yes it does now...
Here is the web link. Tried to copy and paste. Hope it works but looks like it won't.Unfortunately the one that charges money is a rip off of the real CBTricks that is now defunct. At least that is what we all came to believe. Would it be strange that the Rip off site would have updated information that the real one did not?
Would you be able to share the information on the 86v here so all the 86v lovers around the world can have access to it?
Let me know if it worksHere is the web link. Tried to copy and paste. Hope it works but looks like it won't.
Galaxy DX 86V 10 Meter Radio (cb-tricks.com)
Works for me. Every link I tried off that page opens as well. I'd advise those who are interested to grab the info now.Let me know if it works
Yes it works, thanks!Here is the web link. Tried to copy and paste. Hope it works but looks like it won't.
