I also thought about c242, so it's already replaced along with c238 and c239.
D108
Am - Anode 0v / cathode 4.27v
Ssb - anode 4.4v / cathode 3.9v
Q56
Ssb - E 3.8v c13.1 b 4.4
Am - E 0v c13.7 b 0
Thanks for your patience
Ok...I do not want this to turn into a TON of postings chasing Ghosts or using a Shotgun Approach to repairing Equipment that has been left out in the Rain for too many days. After being hit with a Hammer...
Per your advice...
Initial test indicate that;
... a Quantum tunnel has formed at the Junction of The Collectors of Q53 and Q56 - thereby sucking all the Electrons out the Base of Q55 that exists of this Dimension, in thru this Quantum tunnel and out thru a Sand Trap turned Sinkhole at Trumps Golf Course...We're sending a Reporter to the Scene - Please Stand By...
It's beginning to look a lot like Christmas...
Have you been checking continuity amongst the junctions?
Haven't heard anything about if the Limiter even works at Q57
So to me this board's rear corner has suffered a catastrophic failure - you have no voltages, then you have one place that would have no voltage, because they all should be connected hand in hand - but yet has - How? Only thing I can think of is a botched' NPC or we have a radio that suffered an unfortunate fate of torn traces due to it being dropped. This has happened - and it's caused by (for Example) the radio getting dropped on the counter - on it's corner - tearing traces. Botched mods from a previous owner, onto someone used this as an emergency floatation device to get out of a pothole in Newark New Jersey - maybe Recovered remains of something that landed in Area 51 just outside of Roswell...
You'll have to go back, trace to trace and check the foil for continuity to the next junction - its' a PITA but if the radios been in a truck being bounced around - this isn't new - just the bouncing of such a heavy component laden board - can do this as it ages.
- I'm just as frustrated as you are - I'm just venting...
You will find even that Caps, once were insulators, now have shifted and turned into conductors because their plates now touch and show dead shorts. Torque can do this - So this section - shown above, will have to be, gingerly, have those parts replaced one by one until the condition is removed.
As you have already found Q58 is located in a desert Oasis that has a trace from the BACK corner to the front just to apply power to Kill audio from the Mic Amp so FM and SSB can operate.
Lots of places that can have open Foil traces, or broken Resistors or cracked disc caps now failed... as;
this is sold by Weight, not by Volume -
Due to Handling - some shifting and breakage of components can occur without warning
You already know how heavy this thing is - the rest is up to you.
I'll leave this here, to help you locate the TRACES under the components...
I did up a post or two about "shining" to help someone else locate the Solder pads under the components they went looking for.
This is a similar process, again, you can thank Bennie at CB Tricks for even taking the time to post the info so I can process this image - see below...
This is my world,
This is what I work with to help me find answers
for all of you that need help fixing stuff.
To help
GREEN = Ground as in FOIL BOARD Ground (NOT CHASSIS)
Some traces are highlighted to help you decipher, the rest are lined up AS-IS to the original board overlay
