d104 tone control mod
I guess theres only 2 ways it can be done so, if you dont understand english, i'll just solder it both ways, and see which way is correct.
like i said, it appears that in the picture that you posted, there is a lead coming from the top of the resistor and you have it running over to the pot then back into the board again,
so, more or less all you did was replace that resistor back into those exact same solder joints and run the pot in series,there are 2 solder spots on the board where you removed the resistor, i just wanted to make sure that i placed the new resistor back into there perspective solder spots and not get them reversed as to cause me un nesesary soldering.
