Maybe this would cause the signal to sweep in a slightly directional pattern that goes 360 degrees around the antennas?
That’s an interesting thought, lol.
If the frequency of each radio were off from each other slightly, at some point the signals would add and then change to subtract and then back to add. Like the windshield wipers on the school bus. Sometimes they are in phase and sometimes not. Maybe this would cause the signal to sweep in a slightly directional pattern that goes 360 degrees around the antennas? I guess it probably wouldn't do better than one radio by itself.
Now you gave me something to think about, thanks!It would cause flutter at a rate equal to the difference in frequency as the two carriers arrive in and out of phase. If the carriers are off by enough they will beat together and cause a heterodyne squeal at the same frequency that the two TX differ by.
With the 203 amplifiers going for $115 a pair, I have thought about it. Maybe use a coax T and a little CB antenna tuner between radio and amps. The doubling of radiating surface should get you 3 db and the doubling of power should get another 3 db. Can we just keep adding amplifiers and antennas? How far apart should the antennas be? This could be fun....So...just thinking here.
1. One radio into one amp into two antennas.
2. One radio into two amps into two antennas.
3. One mic, two radios, two amps, two antennas.
Option 3 is the problem, correct? By my understanding, the radios couldn’t be “synched”, even if any differences in feed lines were worked out.
Option 1 works. Right?
So what about option 2...two amplifiers into two antennas? Seems possible. Couldn’t you even achieve CP before the amplifiers?
Thoughts?
Thoughts?
How about a beam with multiple driven elements? I can't get this out of my head. Haha
Hi All. Dose anyone run the beam's Horz an Vert at the same time and if so why? Or why not. Thanks.
Maco Circular Polarization Harness
For users who want to achieve circular polarization on their dual polarity beams. The
hand-soldered Maco Circular Polarization Harness allows you to run your vertical and
horizontal gammas at the same time. Perfect for all Maco Dual Polarity Beams, Gizmotchy
Beams, Moonrakers, PDLII,
and more.
New Products from Maco Antennas
As soon as the "radiation" hits the layers it will start to rotate... and thus fast you can not "guarantee" any polarisation can have any favour at a "set time". But overall the majority will be so fast in rotation there isnt any polarisation to favour.
