i turned my radio on the other day and all i get is static.. and i mean a lot of staic like 6 pounds of it or more.. i was wondering if i might have a bad antenna or is the coax bad..the antenna ia about year and half old..
It very well could be some type of interference that we could recognize like 555 suggested. The other possibility is that the matching section of the antenna is blown, causing a dead short. Did you get the antenna new? Do you have any ability to attach a different antenna temporarily to the same coax? Also, do you have the ability to attach a small dummy load to the other end of the coax and measure the SWR? It is also possible that the connector on the antenna side got messed up when you changed antennas.
What state do you live in?
I have noticed different, predictable, noises as the seasons change around here. I live in Upstate New York. I have not identified them but they could be space heaters, electric blankets, electric baseboard heaters, etc. I also know that wet weather really sets off the noise from the High Tension Lines that cross the back of my property.
Please keep us posted - This is always a good learning experience.
Stephen
