I got a imax 2000 up now only able to get swr at 2 can't seem to go any lower not sure if it is the tuning rings because when there loose to turn they are real sloppy like the threads are striped.It has 35ft of coax and it about 40 ft in air
My first question is how you only have 35ft of coax and are able to have the antnenna at 40ft off the ground? How is the coax routed as to only have 35ft of it?? Just curious.
My guess is 2 story house in upstairs room
yes they do lock my mistake these is 50 ft of coax will get a pic and get it in its mounted on my tower which is 4 sections very close to top and the antenna was given to me maybe that's why thought i got lucky numbers ch 1 is a 3 ch20 is 2 ch40 1.7 it seems i can only get 2 and 3 unless I'm turning it to much and over shooting. The peak of my roof there is 7-8 ft to top of tower i think this is a older tower the tower was here when we bought the house last month.I don't know to much about it but on the very top is a scanner ant and no longer in use.That was there when we moved in i tried to go up to remove it but the top of the tower sways when your up there its lag bolted to the house with H brackets but i don't like the swaying when I'm up there don't have that much diamonds like i did when i was younger not sure if that scanner ant is causing it but there not touchingCan you get them to lock on themselves?
What are the numbers at the top and at the bottom?
I had the same thought.
I'm waiting for 2995 to post a close up picture of his Imax, before I try and diagnose any problems.
