imax 2000
Better than getting it all the way up the tower and all connected only to find it was bad. What antenna you going to look into getting? You may want to look into an aluminum antenna. Sirio makes some decent antennas and they make a few antennas that are work very well. The Sirio 827, 2008, 2016, vector 4000, and the Gain Master 5/8 wave antenna are all pretty good. Yes there are many other antennas that you can also look into. A 3 element beam and rotor would be nice, but cost may be a factor. You gotta pay to play as they say!! Don't be discouraged as most of us have been in your situation. I know I have. Just take your time and do some research. Find what will work best for your area. If you don't get bad weather and wind storms, the Sirio vector 4000 is a great antenna. I will vouch for that. After putting mine up I was suprised at how well it did. Making local contacts out to about 65 miles was not hard at all with less then 100 watts at times. Most I ever used was 100 watts and I talked all over the world with it as well as far as across the state of FL at times. That is well over 100 miles. Conditions play a big role, but I was able to make the 65-70 mile trip pretty much every day. And that is straight line I am speaking of, not driving miles!! Anyhow. Like I said, don't get discouraged. You did the correct thing by taking it to a person with the right tools to check it properly. Now you won't be mad as heck when you got it up there and it didn't work correctly!!! Save your money and get a good antenna if need be. Believe me you aren't missing anything at the moment as the DX is pretty well dead. Very sporadic to say the least!!!! Again, don't be discouraged. Sh** happens. Now you have an excuse to get a better antenna;). Not to say the IMAX 2000 is a bad antenna. Just not a big fan of fiberglass antennas myself!! Hope you get it all together. Be safe and hope all works out for you man(y)(y)
not sure what i want to get right now i know years back i had all metal on but to set swr you had to take down and move the tip up or down a real pain then i got a a99 which lasted 10years and had a 1.2 swr all the way around on 10-11meters.I just might get something small for now mount it somewhere else then wait till spring and get one for the tower after i get the safety wear
how good are
Sigma Venom 5/8 Wave High Gain Silver Rod CB Base Station Antenna
All joking aside, I have ben hard pressed to say the I
max 2K is any better than the starduster.
I have both of them up and they both seem to work well.
starduster is around $50, I2K around $120 to $130.
Starduster, assemble it, install it and finish no tuning required.
Same with the I2K, assemble it, install it no tuning as it is factory tuned.
Just depends on what you want to spend.
Reactions: Marconi
I would stay away from the Sigma venom antenna. From all the research I have done they are okay antennas at best. The ground radials suck from what I can see being only a couple feet long.
I would look into the starduster like Wavrider listed. I've heard good things about them. Sirio makes the M400 starduster and they also make a simple 1/4 wave antenna called the GPA 27. Seems to be a decent antenna for getting on air for not much out of pocket. The Sirio GPE 27 5/8 wave antennas work well as far as I know. My local pal has one and it's only about 15ft off the ground and does pretty well. Again an inexpensive antenna. The only other Sirio antenna that I have looked at is the SD27 dipole. It can be setup as both a vertical or horizontal antenna. Not sure how good they are. But they will get you on air. The A99 isn't a bad antenna, I am just not a fan or fiberglass.
And as far as the Sigma Venom 5/8 wave antenna, have a look at the ground plane radials and that will tell you a lot. I don't know how good they are, but for the money at about $65 I wouldn't expect them to be to great. No experience with them myself. I do know the Sirio GPE 27 5/8 wave antennas are good for the money. Also Maco makes some decent antennas but I have also heard about some issues with them as well. Do your own research before you buy and figure out what will work best for you. The M400 starduster is definitely one to consider though. This is from what others have said about them and ones I know that have used or are using them. Like Wavrider stated, they are pretty simple to put together and tune easily and are quite broadbanded from what I can gather. Again, do some research before you buy. And if you are just wanting to get on air, don't worry so much about your tower, just grab a 2" steel pipe and sink it a few feet down in the ground and mount the antenna to it. Tune the antenna and use it that way for now. It's better than having nothing. This is if you are just wanting to get on air. JMHO's.
ws look at the sirio tornado 27 and the m400 just going to do some more reading up on them isn't the 5/8 wave better
Not necessarily. The venom 5/8 antenna you are looking at has very short ground plane radials. Basically they are useless at being on a couple feet long. They need to be 9ft long if there is only 3 of them. Any shorter and it's just useless. If it has more radials like the Sirio 2016 then it would be a different story.
Also, the Sirio tornado is an okay antenna. But it has its downfalls too. It's very lightweight and is not a true DC grounded antenna. It's a transformer grounded antenna. Big difference. You'll need to research this to know the differences. The M400 starduster is a good antenna and I know a few that use them. One happens to be a prominent member here and maybe he will chime in about it. Like I said, you want performance look at the Sirio vector 4000. One of the best vertical antennas made. And not many will disagree with that. Yes it has its shortcomings like not being good in high wind areas, but if you live in an area that this isn't an issue, you will have a great antenna!! Cost is a big factor it seems with the way you are looking, so I will say this, a well built 5/8 wave antenna like the Shockwave made in the USA one cost almost $400. Same with the I10K. These antennas have full length 9ft ground radials and are built for bad weather. Only other options I would look at are the Sirio 2008, 2016, the 827, and so on. They aren't cheap for a reason. The less the price the more lightweight the antenna will most likely be. Like the tornado. I had one myself and it was up 27ft to the feedpoint. It did okay, but after switching to the vector 4000 I would not buy another antenna unless it was something like the Shockwave or I10K or even a Mr. Coily antenna. But like I said the cost of these antennas are not cheap, being at $350-$500 for one. The sirio vector 4000 is a 3/4 wave antenna and has one of the tallest top heights of any antenna made. They are approx 28ft long. And height is might. You get one at 30ft off the ground and tune it correctly, you'll be rewarded with some long distance local talking and some great DX when it's around. Not trying to tell you which antenna to get, but ask around the forum and see what others say. I know the Sirio 827 and 2016 are built well and are strong antennas, but they don't have the length like the vector 4000. Same with the tornado. It's a decent antenna but needs to be modded or have some work done to make it a true DC grounded antenna and also it's not very heavy duty either. So basically the same type wind that would take down a Sirio vector 4000 would do the same to a Sirio tornado. The saying you get what you pay for truly does apply here. Want a heavy duty antenna, again, the Sirio 827, 2008, or 2016 would be my first choices. You want an antenna that will talk pretty far locally and also do a great job DX'ing, look at the Sirio vector 4000. But IMO, I would not buy one of the Sigma venom 5/8 wave antennas due to the lack of proper ground plane radials. Look at how short they are compared to the shockwave antenna and you will see what the difference between a real 5/8 wave antenna and a wanna be is!! The only reason the Sirio 827, 2008, and 2016 work well is due to the amount of ground plane radials they have. They can be shorter as there are many more of them. Don't skimp out on your antenna. I will leave it at that as you will be disappointed you did!! It's the most important part of your entire setup besides the radio. And even so, a $10,000 radio with a POS antenna becomes a nice doorstop!! Do your homework and post another thread asking which antenna will work best for your location. I will venture to say that if you don't have bad or inclement weather and high winds, many will point you to the Sirio vector 4000. But I can only go by what I know about them. With the Sirio tornado I was able to get out to about 30-35 miles. With the Sirio vector 4000 i was able to get out to 60-70 miles consistently. Talked to a group of gents almost every morning and they are 65 miles straight line from me. With the tornado I couldn't event hear them. Take it with a grain of salt. But I spent a lot of time installing both the tornado and the vector 4000. I use good coax (Andrew LMR400), and good connectors as well as having snap on ferrite chokes at the feedpoint of my antenna. Proper grounding and lots of time was taken to make my antenna setup as good as I could. Proper EMP/lightning protection were used as well as making sure everything was grounded. I have over 10 grounding rods sunk in the ground and the entire back half of my house grounded. There is more to having a good antenna setup then just the antenna itself is my point. But starting out with a good antenna is the key.
I am not dissing the IMAX 2000 or even the A99 as I have witnessed others get good performance out of them. But I just am not a fan of fiberglass.
Like I said before you just want to get on air, get a M400 starduster like suggested and have at it. Stay away from the tornado as you will have issues down the road with it. It may last a little while but will eventually start giving you issues as mine did. And one thing I can say confidently about my vector 4000 is that it held its match for the entire time it was up and even during rain and wind storms it never gave me any issues. If I could hear them, I had no issue getting back to them. But don't go by just what I say, let some others step in and give some responses as well. Also you can ask some other members like Marconi, The DB and many, many more about what antenna would be best suited as far as cost versus performance. JMHO's. Hope it might help some. Don't get discouraged, do some good homework and you'll see what antennas rise to the top of the pile as being good antennas!!!
Good day.
Good day.
Do you know what kind of antenna set up (antennas, mast height, power output, etc.) the stations you are talking to are using?
All the guys over in the Ocala area are running either yaseu ft450d, or other radios of the like I believe. No amps. And antennas I am not sure about Rickman330. I'll have to ask when I am able to get back on air. My antenna had to be brought down before the hurricane. I am going to place it back up on a different mast setup. A 40ft push up pole set at 30ft or so most likely.
I will find out though. But I am pretty sure they all run kenwoods or yaseu radios. And like I said no amps for sure. Not sure if they are even using full output power of 100 watts. I know I don't all the time. Most of the time I regulate power to 20-50 watts pep.
Might take me a bit as I said I don't have my antenna up at the moment. I don't think any of them have huge setups, but I could be wrong. They live around the Ocala area and thereabouts. Right at about 65 miles from me. Some possibly a little further. Sorry don't have more info. I just speak with them, have never truly inquired as to what type antennas and such they are using, but have asked about the radios as most of them sound really good. This is all on 38lsb early in the AM, like 4:30-6:00am at the latest.
I also speak with a gent down south of the Kennedy Space Center that runs an RCI 2950 and not sure what antenna, I want to say an IMAX 2k. I hear him quite well too. He is at about 55 miles away from me. He comes in pretty good with just the radio. No amp. I could never hear these guys before. With the Sirio vector 4000 my area of receiving and transmitting went up substantially compared to the Sirio tornado. Burn remember that both antennas were at the same base height just about. Withbin a foot or 2. And the vector 4000 is longer then the tornado. It definitely is a good antenna IMO.
Good day.
i have found a m400 for 68bucks shipped i give it a try set the lower radials 120 i think thats right.See how it does there is times we do get heavy winds that waht took out my a99 i had up for 10 years snaped the center section.
Reactions: 222DBFL
Good day.
found one m400 i'll give it a try set radials at 102 and give it a shot
Reactions: 222DBFL
